Projected Views
Projected Views
cloweRE8TC
Projected Views
cloweRE8TC
With views created by viewbase is it possible to project a view from a face instead of the usual orthographic views?
I need a view projected from the highlighted face below.
Valentin_CAD
@cloweRE8TC ,
Here is a suggestion.
Change your UCS to follow the Face of your object (Yellow Line), then set your view in Model Space.
Now when using VIEWBASE, choose Orientation / Current.
ValentinWSP_0-1713276109857.pngValentinWSP_1-1713276241692.pngValentinWSP_2-1713276651793.pngValentinWSP_3-1713276817114.png
Or use it this method for that particular view and then rotate the VIEWBASE.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
cloweRE8TC
Brilliant thanks Valentin, by basic AutoCAD 3D training didn't cover that.
