Professor and none of my classmates can figure out how to solve this problem using SOLIDEDIT.
AutoCAD and Its Applications - Advanced: Chapter 12 P12-5C
My class mates and I have finished this drawing all the way up to the last edit. It wants us to use SOLIDEDIT to taper the base out 5 Degrees, but no matter how we do it we cannot seem to get it to work. We have found out how to do this without the command, but it is against the spirit of the problem. Has anyone figured out how to solve this?
It gives a hint saying the base cannot be directly tapered, but short of redrawing the object without the filletedge and then using taper from there it will not work with us. Is this even possible?
5. Mechanical Construct the solid part shown using as many SOLIDEDIT options as possible. Then, perform the following edits on the solid.
A. Change the 2.625″ height to 2.325″.
B. Change the 1.625″ internal diameter to 1.425″.
C. Taper the outside faces of the .875″ high base at a 5° angle away from the part. Hint: The base cannot be directly tapered.
D. Save the drawing as P12-5
