Problems with Viewport Scaling
Hey gang,
I'm having a problem with my viewports when I'm changing their scale. I click on the desired viewport. I go to the quick select menu in the lower right, or properties and select the new scale. In the viewport, the scale changes, but the border of the viewport disappears. From here, I am unable to select the viewport itself. However, I can double-click into it to get to model space and everything in the viewport is visible.
This doesn't happen every time I change my scale though. It's seemingly random. I have found a poor work-around. If I change the scale and the viewport disappears, I can click undo to get it back. Also, if I click redo, the scale will change and the viewport will show up as it should. This is random as well. Sometimes when I undo/redo, the problem persists. If I try again, it will usually show up correctly.
Any ideas?
Andrew
