Problems with Touchscreen Input in Autocad 2019.0.1
michael.raede
michael.raede
When using the touchscreen to input lines, I am having two crosshairs on screen.  One at the proper location I am touching the screen, and another about 3 cms beneath.  This double input provides an unexpected behavior on most commands.  The offset distance and relation between the point I am touching, and the second crosshair is always the same.  When drawing a polyline and clicking multiple points along an horizontal line, without using the snap function, I get a sawlike profile.  When using a mouse or the touchpad, behavior is as expected.  I am using a surface pro tablet with normal Autocad.  I know it is not homologated hardware for Autocad, and I should expect performance issues, but the behavior should be normal. Thanks.  Beneath you can see an example of what multiple points along an horizontal line acomplish.Boceto (1).png
0 Me gusta
Responder
Soluciones aceptadas (2)
2.908 Vistas
8 Respuestas
Respuestas (8)
michael.raede
This behavior happens for any screen input: select, draw, etc.
0 Me gusta
No aplicable
I am having the same problem with my surface. MY surface pen does the same thing.
0 Me gusta
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 I haven't ever had access to a Surface Pro so I am resorting to some Internet searches. Have you tried using the Calibration utility inthe Windows Control Panel?
What happens in other graphics programs such as Paint 3D?
John Vellek
0 Me gusta
michael.raede
Thanks for your prompt response. The offset I am experiencing happens only
in the drawing area. The cursor works very precisely in all other areas of
the program, as well as in other programs like paint 3d.
I know the surface is not certified for use in autocad, and because of
that, I was expecting to have certain limitations in use, but this is
obviously a glitch.
I tried the screencalibration, but the problem remains.
Regards.
0 Me gusta
pendean
Community Legend
Community Legend
AutoCAD for Windows is not a true mobile app and the Surface Pen combo has yet to be certified: since you cannot replicate the problem with a mouse or the touchpad it may have to be something you wait for Autodesk to acknowledge the Pen and certify its use.
0 Me gusta
No aplicable
Solución aceptada
I have the same problem the same with my Lenovo Yoga 720 and Active Pen 2. Thank you for reporting the issue here as I was going insane trying to figure out what was causing it. I thought the pen or screen digitizer was faulty but that was a silly conclusion as they worked perfectly elsewhere.
I uninstalled Autocad 2019 and installed 2017. Everything is working now so I will use that version. Thanks again :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
michael.raede
Solución aceptada
Yes, it was a glitch with 2019.0.1. I tried Autocad 2017 and it worked fine, and now that version 2019.1 is out, it also works like a charm. Thanks.
0 Me gusta
michael.raede
Hi.  Thanks for your help. With 2019.1 the problem is fixed.
0 Me gusta
