PROBLEMS WITH SUBOBJECTS FILTER
No aplicable
I work with Autocad 2017. When I am working with 3D objects, I try to select faces, edges or vertex on a 3D object and I can´t because Autocad select the entire object (no diferences between subobjects).
I select the subobject filter in the toolbar, write SUBOBJSELECTIONMODE in command bar or Shift + F2/3/4 etc,  and it doesn´t work; when I try to select faces o edges separately, Autocad select the entire object.
Is this an instalation program problem? I have tried to activate DINAMIC SCP with no success.
Thank you very much.
Mercedes
0 Me gusta
Responder
376 Vistas
3 Respuestas
Respuestas (3)
No aplicable
Could you be trying to select the subobjects of a block?
0 Me gusta
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Have you tried using the CTRL key to select the objects?
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @Anonymous's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
