PROBLEMS WITH SUBOBJECTS FILTER
No aplicable
07-21-2017
02:15 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I work with Autocad 2017. When I am working with 3D objects, I try to select faces, edges or vertex on a 3D object and I can´t because Autocad select the entire object (no diferences between subobjects).
I select the subobject filter in the toolbar, write SUBOBJSELECTIONMODE in command bar or Shift + F2/3/4 etc, and it doesn´t work; when I try to select faces o edges separately, Autocad select the entire object.
Is this an instalation program problem? I have tried to activate DINAMIC SCP with no success.
Thank you very much.
Mercedes
