Problems with layouts
No aplicable
Firstly apologies if I'm posting in the wrong place. I'm very new to AutoCAD and I really need help, I'm using the 2019 student version.
I've drawn up a model and I'm trying to get the model to display in a viewport on a layout template. I've double checked that no layers are frozen and they are all switched on. I've tried new layouts over and over and I just can't get the drawing model to show up in a layout.
Is there some special thing you are supposed to do that I've forgotten?
I've spent so much time on this drawing and probably more now try to view the finished model on a layout and it's driving me crazy. Please help.
0 Me gusta
Responder
Soluciones aceptadas (1)
390 Vistas
5 Respuestas
Respuestas (5)
S.Faris
Refer this : Viewports display blank in paper space in AutoCAD
Don't bother about the Graphic Card mention.
If possible upload your file here.
SALMANUL FARIS
0 Me gusta
No aplicable
I'll give that a try, I've attached the file now.
0 Me gusta
ennujozlagam
Solución aceptada
hello, looks okey now. you have some objects far away from your main drawing. please see attached. thanks
0 Me gusta
S.Faris
I just checked your file and was not able to find a viewport in the paperspace(layout).
Incase if you don't know how to create a viewport:
  1. Click on the Layout tab
  2. Type MVIEW(enter)
  3. Pick 2 points(same as how you draw a rectangle)
  4. Now zoom the viewport and arrange as required.
SALMANUL FARIS
0 Me gusta
GrantsPirate
This would be the perfect time to learn about creating named views while in model space, and then when in paper space insert that view.   In model space, using the Ribbon, go to the View tab, Named Views panel, use the New View command there.  In paper space, using the Ribbon, go to the Layout tab, Layout Viewports panel, use the Insert View command to place.  Scale can be changed during insertion or after the fact.
This doesn't mean you should have objects a long ways away from your main model, just a way to ensure you get what you are expecting.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
0 Me gusta
