problems with duplicate PDF files
Hello good day! , I have a problem, my Autocad is saving me an extra file in PDF from the original file in DWG, will there be a solution to remove that extra saving?, because it is not even a print, it is the original file, only in PDF format
pendean
Community Legend
Community Legend
Do you have AUTOPUBLISH turned on by chance? Look up usage in HELP, appears to be from your post.
not in fact it is disabled, I delete the files and they reappear after saving
vinodkl
Hi @Anonymous
I doubt those are PDFs. I think it's a backfile .bak which has been set to open in a PDF viewer.
In the File browser click on "View" and then checkmark "file name extension" and you would see the PDF file which you are talking about is actually with extension .bak 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
  • It is necessary to have it configured that way, cannot it be deactivated in some way? or is it something by default ?.
pendean
Community Legend
Community Legend
Turn on file extensions in Windows File Manager: I bet they are not PDF files at all, are they?
Here is how to do that https://www.thewindowsclub.com/show-file-extensions-in-windows
Then reassociate BAK files like this https://forums.autodesk.com/t5/autocad-forum/backup-files-are-associated-to-wrong-program/td-p/69847...
