Problems Visualization .DWG
As you can see in the Photo. The previsualization of the layout its okey but when I open it I just get nothing of it.
Could you help me with this ?
Thanks ,
Jon.
imadHabash
i suggest (as a try) to disable Hardware acceleration from 3dconfig command.if the problem still exist please attache the CAD drawing file for testing.
Imad Habash
The problem continue. I will atach the document.
imadHabash
your drawing opened and saved by another application that may cause this issue to you. see below image
i suggest to do the follow :
  • Audit and Purge (Reg) your file. (notice file size that will reach to (1.7MB) ) see attached CAD file
  • this layout visual is fake and not true you have to rearrange your viewports.
Good Luck...
Imad Habash
pendean
Community Legend
Community Legend
Someone moved the model content away from where they used to be when the viewports were created. That's all.
Now you get to fix all of that manually, or enter each viewport, draw a rectangle in it, and manually move your model content back.
There is no automated way to do that: ask the person that moved the modespace content why things got moved around.
john.vellek
Hi @Anonymous,
I believe that Dean is correct. I suspect that the contents of the model were moved (they are below the 0,0 point) and so they no longer are visible in your viewports.  You can either move the model contents in modelspace back to the original location or unlock your viewports and zoom into the proper model areas at the correct scale.
John Vellek
Much thanks for your answers.
Jon.
