PROBLEM WITH XREF'S AFTER INSERTING
I'm using AutoCAD 2015 and Cadworx as our 3D design program. The issue I am having with the xref's is as follows:
1. Make the xref and insert it into the drawing-no problem there.
a. No dedicated xref layer.
2. I need to move the xref around during the design process-here there is a problem.
a. I can move it once, maybe twice, then it freezes up.
1. It will not move.
2. It will not erase.
3. It cannot be manipulated in the xref dialog box.
If I want to use xref's, the only solution I have been able to come up with is to exit the drawing and re-open. Then if I need to work with the xref's the whole process starts again. Needless to say: time consuming and frustrating. The other option I have is to insert the xref object as a block instead. That allows me to manipulate the object, but then it is not an xref.
Is there a setting to check? Any suggestions?
