problem with polyline
Message 1 of 9
problema autocad.jfif
it doesn't let me draw a line like " 1.20".  If a press point it enters somewhere else, I don't know how to explain it because it's the first time happening to me and I can't find anything about it. Please help
Replies (8)
Message 2 of 9
Patchy
Th drawing is upside down, try negative number.
Message 3 of 9
Kent1Cooper
To me, that image looks like you typed in 1,20 rather than 1.20.  When you type X,Y input, it moves over from the X slot into the Y slot when you type the comma.
Kent Cooper, AIA
Message 4 of 9
pendean
Community Legend
Community Legend
Your UCS is rotate: but is your PLAN set to your current UCS too?
Message 5 of 9
yes, my drawing match the UCS. My plan is set to my current UCS
Message 6 of 9
nope, I used "." and it doesn't work
Message 7 of 9
i tried negative numbers too... doesn't work either
Message 8 of 9
Alfred.NESWADBA
Do you mean a segment with 1.20 length? If so look to your command line and use option to _LENGTH
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 9 of 9
if I put a "." in between  1 and 20 for example  ( 1 "." 20 )   it locks the "1". And I can't draw a line with length 1.20 for exameple because after a write 1 and then a put the "." it get locked
And now it all resolved by it self....I don't know how..but yeah. Now I can draw a line with the length 1.20 or 1.30 and so on
