Anuncios
Problem with picking points
dawidtymiukA92S
Observer
dawidtymiukA92S
Observer
Observer
Hello.
I have a problem. When i write coordination (for example line) i chose 50.50. And then when i want to choose another location AutoCAD give me only posibility to write length and angle, but i want to choose length for Y and X axis. And i dont know how to change that. Can someone hel me ?
0 Me gusta
Responder
463 Vistas
9 Respuestas
Respuestas (9)
imadHabash
Hi and Welcome to AutoCAD Forum,
Usually in AutoCAD when you start drawing lines and after picking first point .. just move your cursor for your needed direction then enter the length that you need. >> Click <<
Also you can enable or disable the dynamic input and command prompt that are seen at the crosshairs when drawing in AutoCAD by pressing F12  and/or Change the DYNMODE system variable value . >> Click <<
Imad Habash
RSomppi
Turn off Dynamic Input.
dawidtymiukA92S
Observer
Observer
And what if i still want to see information near my mouse? Before that problem i was able to write values with dynamic input but without need to put angel value.
What i want is to have dynamic input (because it's helpful) and have possibility to write values for X and Y. Not length and angel.
0 Me gusta
dawidtymiukA92S
Observer
Observer
0 Me gusta
RSomppi
Maybe it's Object Snap or Polar Tracking.
0 Me gusta
imadHabash
X and Y direction will follow your mouse cursor .. just move your cursor for your needed direction then enter your distance. Also F8 ( Ortho ) will give you a direct straight lines .
Imad Habash
0 Me gusta
dawidtymiukA92S
Observer
Observer
i see when i type # i have what i want. But i have to type # every time. Is there a way to Just type it once and every next line etc. will work with #
0 Me gusta
dawidtymiukA92S
Observer
Observer
Okay i've found that. Thanks for help
0 Me gusta
Kent1Cooper
Maybe this is what you say you've found [Message 9], but since you didn't specify, and for others' benefit:
Set the DYNPICOORDS System Variable to 1.
Kent Cooper, AIA
0 Me gusta
