Problem with Legacy Image Tile Menus and the Ribbon
Hi all,
I have a problem with legacy Image Tile Menus in my Enterprise menu.
I've noticed that when I attempt to open an Image Tile Menu from the Ribbon, I get a blank Image Tile Menu:
However, if I then try to open an Image Tile Menu from a Pull-Down Menu, the Image Tile Menu appears as expected:
Then, after I've successfully displayed any Image Tile Menu from a Pull-Down menu, all Image Tile Menus display properly when opened from the Ribbon.
The macro syntax in the CUI is the same on the Ribbon and Pull-Down:
$I=image_gh-mech-ex-sd $I=*
Has anyone else noticed this or figured out how to get the Image Tile Menu to open from the Ribbon on the first try?
pendean
Community Legend
Community Legend
This is just a question, not a comment, about your workflows: is there any reason why you've not moved to ToolPalettes or perhaps just ADCENTER after 20+years?
Very good point 🙂
This is an inherited issue, and while I've made sweeping changes to many of our menus and standards over the last 6 years, there are numerous Image Tile Menus to change.
Also, every Image Tile, doesn't just insert a block, but also performs several lisp routines as part of its macro (e.g. automatically inserts at the appropriate scale if required, sets a layer, populates an attribute, etc).
I've made Tool Palettes for all of the Image Tile Menus about a year ago, but they don't quite work the same way.
I'm currently investigating the new Block Palettes feature in ACAD 2020 - hopefully there is something there that will solve this and we can switch over to that.
FWIW, I figured out that the issue may be that the Image Tile Menus are in a partial customization file (my Enterprise Menu).
I was able to get Image Tile Menus to display via the Ribbon (and Toolpalettes) by including my partial menu name before the Image Tile Menu name:
(menucmd "I=gh-menu-acad.IMAGE_GH-MECH-NEW-SD")(menucmd "I=*")
