problem with hatch
problem with hatch
duyguseyhan
Message 1 of 8
problem with hatch
duyguseyhan
Hello. I have a problem with the hatch on autocad 2022. On my laptop everything seems to be fine but when i send the file to someone else the hatch changes its place and size and messes up my work.Seems like it creates a new unnecesery hatch that i can not see on my file,but other laptops can. Can anyone suggest a sollution?
Replies (7)
Message 2 of 8
Alfred.NESWADBA
Can you please
  • upload the dwg-file with the hatch as you save it
  • a screenshot how it looks like on your system
  • a screenshot how it looks like on the system where the hatch is misplaced
  • info about product and version of this second system
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
duyguseyhan
Hi, we both use autocad 2022 student version. I attached the dwg file and pictures of the hatch
Message 4 of 8
Alfred.NESWADBA
the dwg-file you uploaded shows the same hatch on my system as in your first screenshot.
The second screenshot shows at least a different file-name, so something might already have happened to this file ... make first sure that your colleague really opens the same dwg-file.
Side node: your drawing contains 39 errors (found with command _AUDIT)
- alfred -
Alfred NESWADBA
Message 5 of 8
duyguseyhan
Hello again.
This is really weird because I've had this issue for a couple weeks now and everyone i sent files to said the hatch is messed up. I sent another example, don't know if it could be gmail that is changing the file.
Have a great day 🙂
Message 6 of 8
Alfred.NESWADBA
No, if the file would have been changed it would not open again in AutoCAD (at least without recovery).
To make sure ... you are creating these dwg-files. You can open them without any issues.
When you send the files to someone else he has issues with hatches ... and only this one colleague has these issues? In that case it would be necessary to verify the settings of this AutoCAD. Maybe >>>reset AutoCAD profile<<< or uninstall and reinstall of AutoCAD could be necessary (>>>details<<<).
I see your dwg in the same way as your second screenshot.
- alfred -
Alfred NESWADBA
Message 7 of 8
Alfred.NESWADBA
One additional note:
Running _AUDIT with your drawing shows 40 errors with hatches, you should repair the file before you send it.
- alfred -
Alfred NESWADBA
Message 8 of 8
pendean
Community Legend
Community Legend
Share BOTH DWG files please, not just the one: your problem is at the other end where your c0lleague changed it
