Problem with hatch pattern
Message 1 of 17
I have a problem with the hatch command. I want to fill the polyline with a grass patern but for some reason it shows me this (see screenshot). The grass marks from the hatch overlap with each other. Even when i adjust the scale it doesn't give me the pattern i want.
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
You need to change you hatch scale most likely.
Message 3 of 17
perhaps you can post your dwg file so everyone can help troubleshoot easier?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Message 4 of 17
ara_neresesian
Hi
Check your  hatch name it must be grass .
see attached
if everything is correct ,open acad.pat with notepad
search for Grass,it must be like this
*GRASS, Grass area
90, 0,0, .707106781,.707106781, .1875,-1.226713563
45, 0,0, 0,1, .1875,-.8125
135, 0,0, 0,1, .1875,-.8125
you can overwrite this 4 line on yours.
save and close re open the file,if still you have problem
upload your cad file.
good luck
Message 5 of 17
Most likely it's a setting i've to adjust, i get the same result in my other dwg-files
Message 6 of 17
Erense
Copy the red PLine and hatch it. it works fine.
There seems to be a gap between your red and green PLines in the sharp corner on the right.
Close this gap and you have a closed parameter and the hatch will not overlap.
Or (depends on the AutoCAD version you are using) set the HPGAPTOL to a higher value.
For me, I had to explode the red PLine to get the hatch to fill.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Message 7 of 17
Nothing changes if i close the polylines. The problem is the objects that make the hatch pattern (for ex. the cross) are way to large, so that the crosses overlap, making the hatch look like a grid. Scaling does not help (see screenshot). On the lift is the cross pattern with scale 1, on the right with scale 0.1.
Message 8 of 17
Kent1Cooper
@Anonymous wrote:
... the objects that make the hatch pattern (for ex. the cross) are way to large, so that the crosses overlap, making the hatch look like a grid. ....
That looks very much like a corruption of the pattern definition, specifically as though the dash-and-gap specifications [a positive number followed by a negative number] at the end have been removed or commented out or something, so that all lines are unbroken.  Open up the acad.pat file and look at what it has as a definition for the CROSS pattern.  It should look like this:
*CROSS, A series of crosses
0, 0,0, .25,.25, .125,-.375
90, .0625,-.0625, .25,.25, .125,-.375
That definition performs as expected for me.
Kent Cooper, AIA
Message 9 of 17
ara_neresesian
HI
-what is the result when you are printing that file  ,is it same as autocad screen or different?
-cheek your file in layout
-if its different, maybe something wrong with  g.c !
good luck
Message 10 of 17
The pattern stays the same in Layout.
Changing the acad.pad could be an option but i have tis problem for all of my patterns. Also is use AutoCad from a shared server. Wouldn't it be a better idea to create a new hatch pattern?
Message 11 of 17
Alfred.NESWADBA
The defect of that GRASS pattern seems to be inside your ACAD.PAT (or ACADISO.PAT), not sure which one is accessed by your AutoCAD, depending on MEASUREMENT setting.
Can you please upload both, ACAD.PAT as well as ACADISO.PAT so we can see the differences to our files that work well.
Yes, you should be careful with that ... but if that file has defects and you keep on working with that defect patterns, things get worse!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 12 of 17
Well... because i'm working from a shared server, i don't have access to those files.
Message 13 of 17
Alfred.NESWADBA
Then AutoCAD would not have access to these files too ... something is wrong here.
- alfred -
Alfred NESWADBA
Message 14 of 17
It works with a Citrix client program
Message 15 of 17
Alfred.NESWADBA
then you need to ask the admin to replace the ACAD.PAT and ACADISO.PAT with the original one, someone has edited the defaults which should not happen at all.
You might create your own PAT file, but then you need to add a path to the AutoCAD support paths (so AutoCAD can find your PAT file) ... I guess you are not allowed to do that too, correct?
- alfred -
Alfred NESWADBA
Message 16 of 17
If found a way to get access to the acad.pad file, all the pattern-difinitions are same compared to the definitions in previous answers. Is there a way to adjust the spacing between pattern objects?
Message 17 of 17
Alfred.NESWADBA
Than upload the file here so we can look into it and see if the pattern "GRASS" is incorrect or ok.
For a hatch you can only adjust the scaling from AutoCAD.
To edit the pattern itself you need to go through all lines in the hatch pattern definition as this is not just "space between pattern objects" (as every single line in the hatch pattern has to be defined by separately).
- alfred -
Alfred NESWADBA
