Problem with 3D rotation (more than 6 pictures open)
Message 1 of 8
Hi.
I am HVAC engineer and my setup is:
- i7-6700K Skylake
- Nvidia Quadro M2000 4 Gt
- 32 Gt (4x8Gt) DDR4 2133 Mhz
- Asus Z170-P
- Dell 34 Ultrawide
Sofware:
-Autocad 2017 + Magicad HVAC
Problem is:
I usually split screen 2D/3D and like to rotate / view 3D when I am working.
If I have more than 6 pictures open the 3D is not rotating... it only duplicates the view (see attachment).
We have tried to change the graphic gard but its not he problem. Also the ultrawide is not problem.
Any advice how to fix this problem. Thanks.
Niko
Replies (7)
Message 2 of 8
We've seen that before and the solution was a graphics card driver update, but you said it was already updated.  Have you tried turning off hardware acceleration and seeing if it helps??
Message 3 of 8
john.vellek
HI @Anonymous,
This really looks like a Graphics Driver issue. You only list one monitor. Is this really correct or do you have more than one?
What is your Operating System and the graphics driver version that you currently have installed?  Did this works previously for you or has it never worked properly?
John Vellek
Message 4 of 8
john.vellek
Hi @Anonymous,
Have you resolved the issue? If not, please respond to my questions so I can help you to fix the problem.
John Vellek
Message 5 of 8
niko.solehmainen
Community Visitor
Community Visitor
Hi and thanks for the reply.
I am only using one monitor Dell 34" Ultrawide.
My operating System is W10 Pro.
If I turn the Hardware acceleration OFF the is no problem.
So maybe it was the solution.
Thanks.
Message 6 of 8
john.vellek
Hi @niko.solehmainen,
Try installing this current driver for your graphics card. It might allow you to turn the Hardware Acceleration back on.
John Vellek
Message 7 of 8
john.vellek
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post solves your issue or answers your question.
John Vellek
Message 8 of 8
braudpat
Hello
Just a few ideas :
1) Have you tried With HQGEOM = 0 ?
2) LINEFADING = 0 & LINESMOOTHING =0
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
