Problem when Bind xref
mohammed-abdelrahman
Is anyone else having trouble binding large Xrefs in AutoCAD 2024? I tried binding the same drawing in AutoCAD 2022, and it worked fine. Any suggestions?
Simon_Weel
Can you describe the problem with AutoCAD 2024?
When I tried to Xref a drawing, I understood it would take some time to load since it’s a large file (160 MB). However, after attempting to bind the drawing, the application froze for a bit, then unfroze, and nothing changed, I’ve tried multiple times, and the same thing happens, even after cleaning my drawing.
i tried to open a new, empty drawing, and xref the drawing I needed, and attempted to bind it there, but the issue remained the same.
but when I tried this same drawing in AutoCAD 2022, it worked perfectly fine.
error:Error: At least one of the specified xrefs failed to bind for an unknown reason.
Command: Regenerating model.
Regenerating model.
pendean
Community Legend
Community Legend
@mohammed-abdelrahman wrote:
...Error: At least one of the specified xrefs failed to bind for an unknown reason....
Start with this list here to resolve it
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-At-least-one...
