No aplicable
05-10-2020
03:50 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi there
I draw 2d building elevations. I normally draw a window and then use stretch to make it wider, narrower, taller or shorter. It would be great to use some marks to indicate the width I want to window to be and then stretch a window so it meets up with those marks . The problem with doing this is that the marks get to be selected when I select the objects to be stretched, so this messed everything up.
I hope I explained myself?
Is there a way stretch object to a couple of marks indicating the dimensions you want the object to be?
Kind regards, Andrew
¡Resuelto! Ir a solución.
