Anuncios
Problem: Txt+Images imported in Layout view, are under objects in viewport
No aplicable
HEllo,
Using Autocad 2019 on as well Windows 10 as on Mac OSX. On both devices in same drawing this problem:
Text with text tool placed in layout view + Images (jpg) imported in Layout view, are under objects in viewport.
The txt/images seem to be under the drawed objects from the model that are visible in the viewport.
How does this happen?
Text or images placed in layoutview are always on top of what is visible in the viewport. Or am i wrong?
What is the solution so txt/images are back on top.
Screenshot in attachmentn
0 Me gusta
Responder
Soluciones aceptadas (1)
369 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
Solución aceptada
please start command _PAGESETUP (and modify for the current layout) or command _PLOT and make sure the checkbox for "plot paperspace last" is activated. Does that help?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
No aplicable
thank you so much. How did I overlook that option :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes: :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
thanks again, problem solved
0 Me gusta
