Problem Selecting
Problem Selecting
Maxim_1
Problem Selecting
Maxim_1
Hey, I came across a minor issue that I can't solve. I try to select my drawing but instead, it selects the reference (drawing with grey lines), and when I try to zoom in or out, the drawing that I am trying to select stays the same.
Kent1Cooper
Is some of what you show in paper space and some in model space?
Kent Cooper, AIA
Maxim_1
Unfortunately, I do not know that. I'm fairly new to AutoCad, it would be great if you would explain it to me, where to click and so on, to check it.
cadffm
1. Why are you in Layout?
2. Why is your "drawing" in Layout instead in model space?
Run command PSPACE or press [Model] in your statusbar,
you can select the objects now?
Sebastian
Maxim_1
clip
Maxim_1
Thank you so much!
