Problem in size
Problem in size
malikahmedkhan133
Problem in size
malikahmedkhan133
Community Visitor
Community Visitor
I put line command(enter), then (0,0) (enter), now when I have to specify my next point, I put (2,0) but the scale or whatever of the grid is so so so small that instead of a line it looks like a dot. If I do it instead for (200,0) it shows a proper line. So how can I show larger lines even for smaller coordinates like (2,0)?
user181
You are just far away from the line. After you draw the line at 2,0 that looks like a dot try typing the ZOOM command and enter then E for extents and hit enter.  It should be a line that takes up the whole screen then.  You can also double click the middle mouse button for zoom extents.
rkmcswain
R.K. McSwain     | CADpanacea | on twitter
