Anuncios
Problem In Moving Objects
No aplicable
Hello All,
Recently I installed 2016 AutoCAD. It's working fine but whenever I'm trying to move any object within the drawing. It deforms or some other object in touch with seected object also drags or deforms. Earlier I was working on AutoCAD 2014. MOVE coomand was working fine on that. please let me know if i need to do some setting schange or it's some bug.
Thank You!
0 Me gusta
Responder
2.018 Vistas
1 Respuesta
Respuesta (1)
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
>> whenever I'm trying to move any object within the drawing. It deforms [...]
Looking to your screenshot you have activated CONSTRAINTINFER, which automatically connects objects together on there significant points while you create that geometry. So when you draw one line and a second line (starting at the endpoint of the first line) then constraints are build like "endpoint from line one has to be connected to startpoint of line 2" ... now when you move line 2 the endpoint of line one follows the move-vector, looking like line 1 get's stretched.
This could be helpful to read: >>>click<<<
To erase the current constraints use command DELCONSTRAINT (>>>details<<<)
To turn off this mode you can directly edit the setting of the system variable CONSTRAINTINFER or use that icon in the status line
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
