Problem Drawing Rectangle
13917177166
Observer Observer
13917177166
Observer
Observer
 I set the width parameter to 960, and this started happening. Changing back to 0 did nothing
imadHabash
We need to know how did you change the width parameter ?
If you change it from PLINE command ( Width option ) .. make sure that you change both the starting and ending width.
Imad Habash
Observer
Observer
The only change I made was before I specified the first point, I entered d(dimension), and 960,960. I did a quick fix by launching a new blank page, but I need to know how that specific issue can be fixed
pendean
Community Legend
Community Legend
@13917177166 Share with us your actual DWG file with the problem, it has all the answers to your issue.
Kent1Cooper
@13917177166 wrote:
The only change I made was before I specified the first point, I entered d(dimension), and 960,960. ....
In my memory it has never worked that way.  If you give it the Dimensions option, you enter one dimension [and enter/space], then the other.  If you want the two numbers comma-separated but together, give it the first point, and then [without using the Dimensions option], type @960,960.
Kent Cooper, AIA
