Problem about my interface
lturgeonjacques
lturgeonjacques
Community Visitor
Community Visitor
There is something wrong with my interface Autocad.. The fonction group is hidden behind the interface Autocad. I can't see it but I know they are there.
What can I do?
pendean
Community Legend
Community Legend
Did you or someone else change your monitor resolution settings? Sure looks like it
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-change-text...
You might also be missing the 2021.1.3 update (your ABOUT command will confirm if you have it or not).
dmfrazier
"...The fonction group is hidden..."
I don't know exactly what this means, but if you are trying to describe that the ribbon panel labels are missing or hidden behind the Quick Access toolbar, try turning on the MenuBar. This might reveal the control that allows you to change the ribbon appearance. You can then turn the MenuBar back off.
If this is not it, please explain further.
lturgeonjacques
Community Visitor
Community Visitor
It's like my Quick Access toolbar is locked in the upper section of my screen (when Autocad is open, so ribbon panel labels are hidden behind. Even if I turn my MenuBar on and off, it does nothing.
dmfrazier
The QAT has a control that allows you to move it below the Ribbon (Show below the Ribbon).
What happens to the Ribbon's appearance if you move the QAT below the Ribbon? (This is just a test, not a solution.)
This could be another case of an issue with DirectX12. Try setting GFXDX12 = 0.
