When I try to plot point clouds I often get strange rendering artifacts (see attached files). These show up at rather random locations of the plot, though often in roughly the same areas. I've tried chaning settings; using General Documentation and Higest Quality print pdf plotters, tried CutePDF writer, tried setting DPI to low (100), high (300) and ridiculously high (600) - to no avail.
Is there a way to work around this bug?
What are you using to bring in your point cloud? AutoCAD Civil 3D? Map 3D? Infraworks? Plain vanilla AutoCAD?
I doubt it is in your PDF settings. I'd start with the rcp settings then branch out from there. Are you willing to upload your rcp files?
Chicagolooper
Chicagolooper
This is a problem that I've encounted on different computers, on AutoCAD vanilla and Architechture, and with muiltple different rcs and rcp files of varying sizes.
Today I made a quick pdf plot on a different workstation (running AutoCAD architechture 2019) and different point cloud than yesterday. As you can see in the attached file, the problem shows itself again - with a big area in the middle that isn't rendered as the rest of the pdf. This is not something that features in the cloud or is in anyway visible in either Recap or Autocad, it shows up on pdf plot.
Occasionally, a second atempt will come out better (or worse ...). Often, I've experienced that changing the pdf plotter from General documentation to Higest Quality Print improves the plot, but this is not always the case.
Tried again (with the same file as in my first print, on 0.1.48.0 AutoCAD Architecture 2019).
Test 1:
This was made with Highest Quality print pdf. Nothing looks good, some parts look even worse.
Test 2:
And this was with General documentation. It managed to render the bottom-right corner correctly. That's how the entire image should look like.
Test 3:
This is a physical print. The same errors shows up (in slightly different regions), so I concede that the error doesn't lie with the PDF printers.
Test 1:
Test 2:
Test 3:
Could you please tell me how you created that 3d Pdf including the point clouds? I can't do it
Can't do what? Are you trying to replicate my bug or are you just interested in printing a point cloud?
Just wondering if anyone had any luck with this as its a constant source of issues for me.
Best
Best
This looks like it could be some sort of aliasing. Have yall tried changing point cloud density?
CADnoob
CADnoob
Changing the point cloud density? Do you mean some viewing setting in Autocad or do you mean exporting a new cloud from point cloud processing software such as Recap? Because if it's the latter, I don't think it does anything really. For me, as I've said, this problem shows itself trying to print various different point clouds. They haven't all had the same density.
I probably used the wrong choice of words for density, but the idea is the same. Id start by trying the easiest first. The level of detail and point size do affect PDFs i create so id try different setting on those.
CADnoob
CADnoob
