PRINTING/PLOTTING ISSUES IN AUTOCAD 2017
scrosley
Message 1 of 20
scrosley
I'm still having issues with AutoCAd 2017 plotting, this post is similar to my earlier post about xref with a clipped boundary still plotting entities that are clipped.  I attached the a zip file "PDF & Image.zip" which contains pdf files and a png screen shot to demonstrate my point. In my Autocad file, I'm printing from paperspace. I have multiple view ports, in the lower right corner is a viewport that all the layer colors are overwritten through the viewport to be color 253, the attached file "KEYPLAN.PNG" shows what it looks like on my screen (just how I want it). The attached file "KEYPLAN.PDF" shows how it looks when plotted/printed, I tried it on 3 different printers. You can see the whole viewport is filled with color 253 also I added a red rectangle and if you look there are larger circles (Grid bubbles) that are appearing when plotted, that are not shown on the screen, the larger circle are from the xref that is clipped or frozen. The attached file "A4.03.pdf" is the whole page plotted from paperspace, you can see the shaded viewport and clipped or hidden entities. Know here is why I say it is an AutoCAD issue and not my plotter/printers, if you look at attached file "A4.03 DS.pdf" the plot looks exactly like it supposed to, this file was plotted from another cad program that supports .dwg files.
I also included a zip file of my original cad file "A4.03.zip".
I'm using AutoCAD 2017 with SP1, running under windows 10.
Replies (19)
Message 2 of 20
pendean
Community Legend
Community Legend
Un-grouping your location plan seems to cure it.
Message 3 of 20
john.vellek
Hi @scrosley,
Did Dean's suggestion of ungrouping fix the printing of the clipped area?
Please update the status of your issue.
John Vellek
Message 4 of 20
scrosley
Hi pendean,
I ungrouped it however it still plotting shaded.
thanks,
Steve
Message 5 of 20
pendean
Community Legend
Community Legend
Attached is the PDF from your file that I created with DWG TO PDF.PC3 using your own plot style table, and your file (AUDIT found errors, PURGE found a lot to get rid of). I see not problems.
Message 6 of 20
scrosley
Hi Dean,
I downloaded your attachment of the A4.03 drawing and it did plot correctly. however I noticed all your lines were white in paperspace, I'm not sure if that had anything to do with it. I did open my drawing with recover and found no errors also purged and mine still does not plot correctly. The only other thing that may be an issue is that I bound the xrefs before posting it so now attached is a zip file of my drawing with the xrefs not bound.
I have the windows anniversary edition, I read that there are some known issues with it. It is a new computer and It came that way so I can't roll back.
By the way how did you make everything white on black in paperspace? the lines are in color in model space and I don't see any overides?
Steve
Message 7 of 20
pendean
Community Legend
Community Legend
>>>...however I noticed all your lines were white in paperspace...<<<
Go into pagesetup command in that layout and uncheck the box DISPLAY PLOT STYLES. I used that feature to double-check your plot style table before plotting. It has nothing to do with whether your file plots or not.
I'm not on WIn10 and I don't have your HP plotter: it may be the latter, I'm not sure the former is being reported as an issue.
Message 8 of 20
scrosley
Thanks for the tip!
I did try printing on a few different printers but with the same results.
Message 9 of 20
john.vellek
HI @scrosley,
Here is what I got using your plot syle and sending it to AutoCAD PDF (General Documentation PC3)
I ran audit and purge on your drawing and then an Exporettoautocad since the drawing was apparently created in a different application.
Please let me know if this looks correct.
John Vellek
Message 10 of 20
scrosley
Hi john,
Thanks for your input,I downloaded your attachment and it does plot correct. I did try the export to autocad on my file however sit still shows the shading and the hidden entities too, see attchment. The drawing was created in autoCAD but the xref came from another source so maybe that is part of the problem?
Message 11 of 20
john.vellek
Hi @scrosley
Where is the xref? Can you attach it for me?I didn't see anything in the xref manager when I looked at your drawing.
John Vellek
Message 12 of 20
scrosley
Hi John,
attached is a zip file with the main and xref files.
thanks,
Steve
Message 13 of 20
john.vellek
HI @scrosley,
To me, it looks like the problem lies in the viewport itself. I created a new one next to it and started freezing layers and changing vp colors and all that. When I do a plot it now looks the way it should.
John Vellek
Message 14 of 20
scrosley
Thanks John,
It is the viewport, however I can duplicate the problem with a new viewport. I create a viewport, set it to a scale, and lock the viewport. I then activate the viewport and then go to the layer manager. In the layer manager I sort by layers turned off, then I select the xrefed off layers and give them a color of 252. Then do a print preview and the new viewport is shown shaded and displays layers that are off. I'm not sure if all these steps are required but I am narrowing down the problem.
I normally don'y overide frozen or off  layers but sometimes it is easier to select all the layers and change the color than to try and figure which ones actually apply yo the viewport.
Steve
Message 15 of 20
john.vellek
Hi @scrosley, Can we try another new viewport? Let's not worry about scale and locking until we freeze EVERYTHING that we don't need and then reassign all the remaining with a color such as 251.
BTW, when I did this I first did audit and purge and exporttoautocad on each of the files.
Please let me know how this works for you.
John Vellek
Message 16 of 20
scrosley
Hi John,
After an audit and purge the exporttoautocad;
Attached are 3 images:
VP1 - I created a new viewport and froze layers through the viewport, prints fine.
VP2 - Next I changed the color of all visible layers through the viewport to 251, prints fine.
VP3 - Next I changed the color of all off layers through the viewport to 251, there lies the problem.
Message 17 of 20
scrosley
Hi John,
Just as a test I changed the layer colors to white in the original viewport that was shaded and now it prints ok., see attachment.
thanks,
Steve
Message 18 of 20
john.vellek
Hi @scrosley,
Excellent - at least now we have a way for you to keep producing. In the mean time I will try to duplicate and log as a defect if necessary.
Thanks for your patience on this issue.
John Vellek
Message 19 of 20
faragello
I share printed out as PDF file for your dwg .
is this solution to you you can do
The FRAME system variable overrides the XCLIPFRAME setting. Use the XCLIPFRAME system variable after the FRAME system variable to reset the clipped xref frame settings
0
The frame is not visible and it is not plotted.
The frame temporarily reappears during selection preview or object selection.
1
The clipped xref frame is displayed and plotted
2 The clipped xref frame is displayed but not plotted
Message 20 of 20
scrosley
Hi faragello,
Thanks for the suggestion, however it is not the frame that I'm having problems with printing. The problem is xrefed cad entities that are on a frozen layer are printing because the xrefed layer color is over written to a different color.
