Printing layouts automatically over multiple pages
bencharlton5C8EZ
bencharlton5C8EZ
Hi All
I am sure this is a very basic question but I wouldn't even know what to search for to try and get an understanding of how to achieve what I am after... In the past I have struggled through manually moving the model space around in the paper space, printing and repeating so that I can print off drawings larger than I am able to in 1 go... to 1:1 scale which I can physically join together and lay out.
Is there a way I can ask the program to automatically generate say the 8 A4 sheets required for an A1 sized drawing so that they can be printed on an A4 printer?
pendean
Community Legend
Community Legend
Good question: AutoCAD does not do that in any automatic way whatsoever, never has. You'll want to print your A1 sheet to PDF, then use a PDF Viewer/Editor that has the ability to split up your 1-sheet into 8-sheets.
If you only have and need to use AutoCAD, it appears you are aware of that manual process of creating what you need.
HTH
bencharlton5C8EZ
Ah OK, thanks for taking the time to reply!
