Printing directly without publishing
No aplicable
I wanted to know how we can print a large number of DWG/DXF files directly to printer without publishing it to PDF. I am able to send a drawing file straight to printer but unable to send more then one file straight to printer without publishing it to PDF. Any form of help will be highly appreciated.
0 Me gusta
Responder
302 Vistas
4 Respuestas
Respuestas (4)
j.palmeL29YX
Do you know the SheetSetManager?
Or you can use a scipt file.
cadder
Jürgen Palme
0 Me gusta
ian.mag
Hey,
As pointed in the above comment by @j.palmeL29YX , sheet set manager is a powerful tool that enables you to manage your sheets. You can get started here
maratovich
No problems.
Use this:
https://youtu.be/rK9WLeJHA1M
Print from model or layouts.
You can select many files at once or specify a folder with files.
You can choose any printer.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
0 Me gusta
pkolarik
Why not just simply Publish your dwg files direct to the printer? (use the built-in Publish command, but skip the pdf step)
0 Me gusta
