printing A3 on autocad both edge is cut off
hello everyone,
i have this problem were i tried to print A3 but print out both edge is cut off . anyway it printed well on other sizes. i tried every solutions posted in internet but none working with me. i tried save to pdf then print as A3 and it work well. which means it work well outside autocad.
HP Officejet 7510
Please need your immediate reply, thank you
Alfred.NESWADBA
What is meant by "both", left and right, or top and bottom, or ...?
What happens when you use the device "AutoCAD PDF (General Documentation).pc3" to create an A3-PDF file ... and then print the PDF with 100% to your printer?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
i printed on landscape so left and right is cut off, and about converting to pdf then print from pdf is perfectly find, but the problem is when i print directly a3 from autocad. i already reinstall my printer but same problem, tried printing from layout or in model tab but still edge is missing.
Alfred.NESWADBA
As you are in hurry I guess that's the best we can suggest know.
To go more deep it needs to look into the drawing + the PC3 + the PMP (if there exists one) + a photo from what you are getting on paper.
Version of AutoCAD + operating system might be important info's too.
- alfred -
Alfred NESWADBA
i see, i ask for future use ,. and btw i remember it happen when i install autocad 2020, .
thanks anyway.
Alfred.NESWADBA
Half information ... does that mean you had installed a different version of AutoCAD before and that was working well? If so did you migrate settings? If you migrated settings then this might have imported not just settings. If you have not done too many customization you might reset the AutoCAD profile to default (>>>details<<<), next time when AutoCAD starts please do NOT migrate settings and try plotting again.
Well, to get an answer for the future we have to inspect the data you have now, so you can avoid to do the same again.
- alfred -
Alfred NESWADBA
yes i was using 2016 version and working well then after i install 2020 then that happened. sorry i just remember when it started. i will try to reset it and i will let u know . thank you so much .
