Printer HP 7720 not works in color
No aplicable
Guys, I have an HP 7720 printer, autoCAD is not allowed to print colorfully. I already posted this question in the HP Forum, I did the step by step that they asked, excluding the printer and reinstalling, it and autoCAD. Unsuccessfully. I ask them how can I change the option in vector graphics if the color option is inactive ???
0 Me gusta
Responder
Soluciones aceptadas (2)
4.300 Vistas
19 Respuestas
Respuestas (19)
Alfred.NESWADBA
which version of AutoCAD and which version of operating system do you have installed?
Is the missing color output a result of one dedicated drawing? What happens when you create a new drawing, one line on a red layer and plot this?
What happens when you plot to "DWG to PDF.pc3" ... is that PDF file showing colors? If yes, print that PDF-file to your plotter, what's the result?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
No aplicable
Hi, how are you? My operating system is W10 64 bit, and the autoCAD I'm using is 2013.
Yesterday I downloaded the 2017 version and had the same problem.
Using "DWG to PDF.pc3" the design is perfect, comes out colorful and in good definition.
Already using the HP 7720 plotter it comes out in grayscale at all times.
I noticed that it is the "Vector Graphics" option that is inactive and already set to monochrome.ics" option that is inactive and already set to monochrome.
0 Me gusta
Alfred.NESWADBA
not sure if you have answered that:
And when you then print the PDF .. does that appear in monochrome or in color on your printer.
HP is not the best supplier for Windows 10 drivers, try to use the universal printer driver (PCL) >>>click<<<
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
"DWG to PDF.pc3" is an existing virtual printer and any autoCAD ... There is no what you want, I reply that it is not pdf format the drawing comes out perfect, not colored and black on black, it must be obeying the CTB . On the HP 7720 everything comes out in gray.
Well, I use windows 10 which is the system of the present time ....
0 Me gusta
john.vellek
HI @Anonymous,
I installed the HP driver (OJ7720_Full_WebPack_44.3.2218.exe) on my Windows 10 computer.  I launched my oldest installed version of AutoCAD (2016).
When I set up to plot, it shows up in color.  Have you tried printing from other applications in color to this device?  Is it only AutoCAD that does not show this selection available?
Are you able to access the Color Management in the driver to see if there are entries?
John Vellek
0 Me gusta
No aplicable
Universal troubleshooting on the one hand, but none of these drivers detected an HP 7720 or an HP 3776.
0 Me gusta
No aplicable
Hello! This problem only happens in autoCAD. I tried to access the color configuration inside autoCAD and it appears inactive ... Do you believe it can be my Windows, I installed it recently, since I changed hard disk ... Including yesterday I installed the version of autoCAD 2017 the problem persisted. I send pictures of what happens.
0 Me gusta
john.vellek
Hi @Anonymous,
Are you running this printer from a server?   Can you print straight to the IP address of the device to see if it makes a difference?  The port address looks strange (from the the plot window image).
AutoCAD 2103 is not designed to run on Windows 10 so I suggest that you download a current product such as AutoCAD 2019 for testing.
John Vellek
0 Me gusta
No aplicable
Sorry, but the problem happens in 2013 and 2017. My printer is not on a server, it's on the WIFI
0 Me gusta
john.vellek
Hi @Anonymous
Is it possible to make an ethernet or USB connection to the printer to see if it works?
John Vellek
0 Me gusta
No aplicable
I try, but not differency. Ever Monochrome.
0 Me gusta
john.vellek
Hi @Anonymous,
It is difficult to tell from what you have shown , but can you verify that you used the same driver that I did?  I also see from HP's site that there is a firmware update  (August 201) that you check on as well.
John Vellek
0 Me gusta
No aplicable
Type:
Firmware
Version:
1830A
Operating systems:
Windows 10 (64-bit)
Release date:
Aug 3, 2018
File name:
OJ7720_1830A
(77.6 MB)
0 Me gusta
john.vellek
Hi @Anonymous,
That information points to the firmware update and not the print driver.  I used the 44.3.2218 version and see the color option.
John Vellek
0 Me gusta
No aplicable
You had talked about the firmware version friend ... So I sent you a previous message, I'm also having a driver version 44.3.2218
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
Let's try this please. Download a Trial of AutoCAD 2019 and test to see if you are able to select the color option. Make sure you are selecting the system printer and not a PC3.
If you are still unsuccessful, I suggest removing the driver entirely and then reinstalling it as I have no problem accessing the color with my AutoCAD 2017.  This appears to be a Windows or driver issue.
John Vellek
0 Me gusta
No aplicable
Solución aceptada
Hello friend, how are you? I was traveling. Today I installed the autocad 2019 and to my surprise, is woooooooooooooooooooooooorkiiiingggggg, an HP 7720 printer is colorful! I was very happy.
john.vellek
Hi @Anonymous,
I am glad that the newer version of AutoCAD works with the driver.  If the older versions do not, you might try using the HP Universal driver to see if that helps.
John Vellek
vinodkl
@Anonymous  May I know why your spamming this forum, by posting things which are not related to this topic or AutoCAD?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
