AutoCAD Forum
Print with hidden lines
8 REPLIES 8
Message 1 of 9
tmccar
3425 Views, 8 Replies
I have a PS viewport which shows an isometric view in hidden line mode. But when I print to pdf, it switches to wireframe.
How can I  print in hidden line mode?
8 REPLIES 8
Message 2 of 9
cadffm
in reply to: tmccar
Sorry.
Sebastian
Message 3 of 9
imadHabash
in reply to: tmccar
>> But when I print to pdf, it switches to wireframe. <<
is there any page setup that you use ? if not , check your VP's visual style . also you can select your VP then Ctrl+1 and change your Shade Plot from Misc tab .
Imad Habash
Message 4 of 9
peterm
in reply to: tmccar
Make sure Shade plot is set to "As displayed".
Message 5 of 9
tmccar
in reply to: peterm
Shade Plot is greyed out, so I can't access it.
Message 6 of 9
peterm
in reply to: tmccar
Can you post a drawing that has this problem?
Message 7 of 9
tmccar
in reply to: peterm
Ok, it's posted
Message 8 of 9
peterm
in reply to: tmccar
I'm not sure why that option is greyed out on the plot dialog, but I had no problem setting the viewport to hidden line and then plotting (see attached pdf).
Message 9 of 9
sdg289
in reply to: tmccar
- Right click Properties to open Properties Palette.
 -Select the viewport, and change the "shade plot" to legacy hidden on the Properties Palette.
Forma Design Contest
