Anuncios
Print Offset in Layout space
dm0144
dm0144
Hello everyone
When ever I try to print directly from Autocad on custom paper size, the layout becomes offsetted from the paper, even though both are at the same coordinates (0.0) therefore, the print is slightly moved to one side.
To go around this issue, I use Window option to select the printing area instead of Layout in the Layout space.
Does anyone else encountered the same problem?
Any causes and fixes?
Regards
0 Me gusta
Responder
Soluciones aceptadas (1)
1.157 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
Solución aceptada
A screenshot of your PLOT command with the layout option ready to go would be better to post.
Do the same with your ABOUT command pop-up please.
0 Me gusta
travisgoffZ2B3C
I was experiencing the same issue. I looked for an answer here & elsewhere, looked at my plot settings, and was not able to come across what is very likely a simple solution.
So, my simple workaround (until I learn what is causing this) was to move my title block (& viewports, along with peripheral objects I keep in paper space) so that it appeared centered when plotting. I then made the same adjustment in my personal template.
I will move them back one day when I learn how to directly resolve the issue.
0 Me gusta
