Print Multiple DXF files which don't have page setups
RFreund
RFreund
Is there a "best" way to do this? I have 100's of dxf files which have cutting diagrams for fabrication. They are all about the same size and I know that I want them to print on an 8.5x11 at 1/4"=1'-0" but really it could be any size and any scale.
I'm trying to avoid going into every file and creating a layout or even opening the file and CRTL+P then just using a window. Is there some way to automate this or even if I need to open every file, is there a "fastest way"?
Ryan
cadffm
Fastest ootb way.
Just one possible setting, but the way is the important thing you want to know.
Create a dwg,
Go to model or to a layout (choose what space you want to plot).
Create a circle(just if you use extents as plot area option), DO IT for this test.
Command PLOT
Set up a pagesetup you want to print,
in this case for example
DWG to PDF.pc3
Maximum Paper size you guess to need.
Plot area set to extents
Plot scale 1:1
Save this pagesetup with a name(upperst option in plot dialog).
Apply, Cancel or plot.
Save the file.
Now you can set up your command PUBLISH job.
Add all ( or for testing just some)models or layouts from your files,
select all of them in your list
Rightclick in the column for pagesetup
Import, choose your new dwg, select your named pagesetup.
Run this job..
First make sure: Background publishing is off,
because it makes trouble often and it is slow.
Sebastian
cadffm
One "Standard" custom support file is such a dwg with my standard pagesetups i need often.
Layout color A0 landscape 1-1 PDF
The same for monochrome
and so on
for paper plotter..
Portrait
Plotscale FIT
Sebastian
guidi.alberto
Community Visitor
Community Visitor
Hi! Do this procedure works also for .dxf files? I am trying to publish several dxf files, but when I am tryingo to import the page setup from my .dwt file the page setup is not loaded. How I need to solve?
cadffm
Sure.
Sample attached, extract the file to c:\temp and start command: publish
load the DSD list and try it yourself.
In my sample  I am publishing 2x modelspace(1+2) and 2x Layouts (3+4),
I used the pagesetup saved in my *.dwt file.
Think about:
Model pagesetups are for modelspace (Model) only,
layout pagesetups are for paperspace(Layouts) only,
because of I publish from model and layout in my sample -
i have save one model- and one paperspace pagesetup in my .dwt file.
How to config the pagesetup from an external file to the list:
Sebastian
guidi.alberto
Community Visitor
Community Visitor
Wonderful! It finally worked. I was tryng to use a layout tamplate for model.. Dankeschön!
RFreund
