Print filename
Print filename
No aplicable
I would like to see the Filename printed in the under the  bottom line of the title block in the plots. (maybe a complete Path?)
0 Me gusta
Responder
Soluciones aceptadas (1)
2.278 Vistas
7 Respuestas
Respuestas (7)
No aplicable
Trying turning on the Plot Stamp in the plot dialogue box.
K
0 Me gusta
Vinayv4v
You can insert a field containing the file name at the bottom of your title block.
Cheers,
Vinay Vijayakumaran
No aplicable
I'll give this a try.
Kind Regards,
Juanito Veluz, Implementation Coordinator
m. (416) 938-9204
o. 1-855-646-6242
f. (902) 469-6825
Juanito.Veluz@mobia.io
MOBIA Technology Innovations
Halifax | St. John's | Montreal | Toronto | Edmonton | Calgary
www.mobiai.io
m. (416) 938-9204
o. 1-855-646-6242
f.
Juanito.Veluz@mobiainnovations.com
Halifax | St. John's | Montreal | Toronto || Calgary
www.mobia.io
Confidentiality Warning: This message and any attachments are intended only for the use of the intended recipient(s), are confidential, and may be privileged. If you are not the intended recipient, you are hereby notified that any review, retransmission, conversion to hard copy, copying, circulation or other use of this message and any attachments is strictly prohibited. If you are not the intended recipient, please notify the sender immediately by return email, and delete this message and any attachments from your system. Thank-you!
Information confidentielle: Le pr?sent message, ainsi que tout fichier qui y est joint, est (sont) envoy?(s) ? l'intention exclusive de son ou (ses) destinataire(s); il est de nature confidentielle et peut faire l'objet d'une information privil?gi?e. Nous avisons toute personne autre que le destinataire pr?vu que tout examen, r?acheminement, impression, copie, distribution ou toute autre utilisation de ce message et tout document joint est (sont) strictement interdit(s). Si vous n'?tes pas le destinataire pr?vu, veuillez en aviser imm?diatement l'exp?diteur par retour de courriel et supprimer ce message et tout document joint de votre syst?me. Merci!
0 Me gusta
john.vellek
Hi @Anonymous
In AutoCAD I like to capture the filename with a FIELD.
I made a quick video to show some of the possibilities.
John Vellek
0 Me gusta
No aplicable
Can you please send me a link to the video.
Kind Regards,
m. (416) 938-9204
o. 1-855-646-6242
f. (902) 469-6825
www.mobiai.io
m. (416) 938-9204
o. 1-855-646-6242
f.
www.mobia.io
0 Me gusta
john.vellek
Solución aceptada
Hi Juanito,
Of course! Here you go.
https://knowledge.autodesk.com/community/screencast/914c60b8-857c-4dba-b651-bef480e65d40
John Vellek
0 Me gusta
No aplicable
Here's a block with fields to give you a head start.
0 Me gusta
