Print drawing on 1:1 scale to multiple pages
Hello, I just started using autocad for the very first time for a little project and I have a question about printing files.
My file is a template for cutouts, it is larger than a piece of A4 paper wich is all I have to print on.
now I want to print this file to multiple pages which I can later tape together to get my 1:1 scale template.
any help would be appreciated.
Alfred.NESWADBA
do you print from model-space or from layout?
If printing from modelspace you have to select 2 different window areas to plot, left half then right half.
If printing from layout then create a layout, one viewport, defined the part of the model (and scale) for that viewport to see one half of your model. Then copy the layout and use _-PAN in the viewport to pan the content of the viewport to see the second half of your model.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
Hi and Welcome to AutoCAD Forum,
>> now I want to print this file to multiple pages which I can later tape together to get my 1:1 scale template. <<
i suggest to do the follow [ Model space ] :
  • draw a rectangle that represent your A4 page size and put it on Defpoints layer ( for non print issue).
  • now start to copy that rectangle to cover all of your template and with overlaps area .
  • i suggest now to put small marks in those overlaps areas like small circles or lines ...
  • start to plot every rectangle with proper settings and scale  .
  • if your successful printed pages is out , now start to combine them and matching those small marks .
this is a very fast and simple way ... hope it's help . 🙂
Imad Habash
john.vellek
Hi @Anonymous,
There are some add-ins in the Autodesk App Store that might help you do print tiling.
I am curious however if you could share your file so I can show you how I have done this process in the past.  I usually draw Pinter Crop marks at the corner of each area that will be printed separately and will provide matching points to align the prints once they have been completed. I then use viewports and ALIGNSPACE to get the rectangles to fit in a separate layout each on its own layout page.  This then allows me to us PUBLISH to create the whole set of prints all at once which can save lots of time.
John Vellek
john.vellek
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.  If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
John Vellek
