Prevent Dimensions in a Block From Being Mirrored
dm0144
Message 1 of 12
dm0144
Hello everyone
Is it possible to prevent dimensions in a block from being mirrored when you mirror the entire block, without exploding the block?
It would be super helpful and time saver if I could make a block for a building section, which includes the dimensions, and than use it as a reference section in multiple drawings, so when I make changes to the section(ex. changes in thickness, position of elements...), I don't have to manually update the dimensions on each referenced block?
Regards
Replies (11)
Message 2 of 12
Sounds like you could benefit from using >dynamic blocks<, specifically a flip action. This will "mirror" the block and keep things like text, dimensions, leaders, etc oriented correctly.
Hope this helps, if not, post back.
Message 3 of 12
dm0144
Thanks for writing back:)
I added a flip action/parameter to the dimension line inside the block and it didn't solve the issue. When pressed on the arrow to flip the dimension line on the mirrored block, only the dimension line flipped along the axis and not the text, which is the main issue. I tried to flip the dimension line around horizontal and vertical axis. In both case, the text was not effected. It remained as in it's initial, MIRRORED orientation.
I am looking to solving this problem.
Any help is more than welcomed:)
Message 4 of 12
I would suggest setting the axis of the flip parameter at the center of the block, and including all of the geometry, text, etc. in the flip action. If you want an example,  post a dwg file with your test block.
Message 5 of 12
dm0144
Tried including the object, which is being measured, and the dimension line as well. I didn't work for me.
Hope you can figure it out.
Message 6 of 12
Try this one- I included both dimensions in both flip actions.
Let us know if this is what you were looking for.
Message 7 of 12
dm0144
In the file you send, the object is copied and the dimensions are flipped around the object, on each side.
That is not what I am looking for.
My issue is that, when I mirror a block instance, the text of the dimension remains mirrored, and I can't figure how to flip the text back, meaning it can be ''readable'' and not mirrored. But the object has to remain mirrored, therefore, the block has to be mirrored because I want to have it as a block instance.
Message 8 of 12
I'm going to have to bow out of this one, no idea how to do that...sorry.
You will probably have better luck in the >dynamic blocks forum<
I thought maybe >visibility states< selecting between dimensions with text rotated and/or reading direction reversed, but it seems prohibitively cumbersome to cover every eventuality/possible text position that way.
Message 9 of 12
imadHabash
No , it's not possible . Sorry .. this is the fact regardless of any other tricky way.
Imad Habash
Message 10 of 12
I feel a little better knowing the reason I couldn't figure it out is that it is impossible.
-Thanks-
Message 11 of 12
s.borello
Make your text an attribute, you will then have control over rotation.
Message 12 of 12
dm0144
I am specifically interested in dimensions (distance annotation) within a block. When the block (which contains the dimensions) is mirrored, the text (the number) is mirrored as well. That way is not "readable". This is the issue I am searching for a solution. I would save a lot of time if I could fix it.
