Presspull direction
Presspull direction
Presspull direction
hi when using presspull and pulling a object in the negative z axis it goes the wrong way
can any one help please
Vinayv4v
Try turning off you osnap (F3) and try.
Cheers,
Vinay Vijayakumaran
Thanks for that I'll give it a try
imadHabash
Hi and Welcome to AutoCAD Forum,
If you selected a 2D object or clicked inside a closed area, specify an extrusion height by moving the cursor or entering a distance. The extrusion direction of planar objects is normal to planar objects and in the Z direction of the current UCS for non-planar objects.
Imad Habash
Thanks for your assistance
