Precise Cuts on M-Lines
cadman777
Advisor Advisor
cadman777
Hey Guys,
This is a novice question, since I've just begun trying to use M-Lines.
Would someone please tell me how to PRECISELY CUT M-Lines?
When I put a door in between the M-Lines, I want to cut one or both M-Lines at the beginning and end of the door frame. How do I do that WITHOUT exploding the M-Line? I can use the M-Line Edit tools, but don't know how to SNAP to the objects that aren't M-Lines. Is there a command like my custom made LISP 'BREAK' command that allows giving a first and second point AFTER selecting the M-Line object needing to be cut (it BREAKS between the 2 picked points)?
Thanx ...
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
ara_neresesian
HI
try trim .
cadman777
ara,
Thanx for the quick response.
TRIM doesn't work the way I want it to.
Sometimes I want to trim only one of the M-Line lines.
Trim will trim the whole thing.
It also breaks the M-Line into 2 entities.
Any other ideas?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
ara_neresesian
HI
there is no way to do like,you need to explode the m -lines.
with plain Autocad no way,  maybe its possible in Auto cad Architectural ,nut sure.
cadman777
Thanx.
Too bad, b/c I'm guessing this is a need that's been waiting to be implemented for at least a DECADE.
SOS ...
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
cadman777
I figured out a work-around:
1. Drop your doors and windows into the walls.
2. Draw a line where the door and window extents divides the wall.
3. Activate the TRIM command btw those two lines.
4. Delete those two trim lines.
Done.
This is a real stupid way to do it, but it works.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
