Anuncios
Prabolic Duct in Rectangular Block
No aplicable
Hello All,
I am trying to model a rectangular 3D slab with size 4.3mX1.6mX0.16m with a duct of 15.7mm.
The duct should start from center at one end and then should go parabolically to the other end ending again at center. the maximum depth of duct should be 50mm .
How can i do that?
0 Me gusta
Responder
Soluciones aceptadas (1)
736 Vistas
9 Respuestas
Respuestas (9)
Kent1Cooper
I'm having a hard time imagining what you're describing.  An image [even a scan of a hand sketch] would be very helpful.
Kent Cooper, AIA
0 Me gusta
No aplicable
hi,I am Attaching a sketch of it. I need a rectangular slab with a duct in between which is parabolic in nature.(the duct varies parabolically)
Thanks in Advance Regards,Prashant MotwaniResearch Scholar, Civil Engineering Dept.Indian Institute of Technology(IIT), BombayContact: +91-9981135555Email: 164040005@iitb.ac.in, motwaniiitb@gmail.com
0 Me gusta
Kent1Cooper
[nothing attached....]
Kent Cooper, AIA
0 Me gusta
No aplicable
Sorry for that. PFA
0 Me gusta
imadHabash
Solución aceptada
Sweep command will serve you.
A sample.dwg attached..
Imad Habash
0 Me gusta
No aplicable
Are you modeling tension rods in the slab?
0 Me gusta
No aplicable
no i need to model postension strand in the parabolic duct.I am going to export the slab in ABAQUS and do its Finite Element Analysis. Can You help in modeling ?
0 Me gusta
SEANT61
I guess the remaining concern would be the Parabola.  That can be made using a degree 2 spline.
I'm not sure about all the dimensions, specifically the duct dia.(15.7 ?), or what the 0.05 M drop refers to (duct wall), but the attached is my interpretation.
May your cursor always snap to the location intended.
0 Me gusta
SEANT61
This screencast demonstrates the viability of a degree 2 spline as a parabola:
0 Me gusta
