pop-error-mode underflow error message.
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Hi all
I keep getting this error message when trying to use the Bcount command.
However when I closed the drawing and reopened it disappeared.
No longer a problem.
Just curious to know why it happened
Mike Kovacik
Autocad/Inventor Designer Draughtsman
Joburg
South Africa
pendean
Community Legend
Community Legend
Who knows... it happens in software, that's why the #1 tip for fixing a problem is always either restart the program or restart Windows 🙂
jayhar
I found that SELECTSIMILAR works for dynamic blocks that have the same dimension width ...
but if they are have a different width quantity ... then they are not recognized
also on the command line I only had a value of one block ... eventhough I had copied two additional ...
...but it is a new command that I can utilize
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
