Polyline linetype
Polyline linetype
No aplicable
I have a problem with polyline. It has dashed linetype but some of its segments visualize in a wrong way - as continuous. The linetype scale is right as you can see on the picture. If I hoover over the polyline, I can see the preview of completly dashed line.
In paper space it looks the same way, only when I zoom really a lot regen all I can see the line is correct.
 Please help, it's really confusing.
Jana
0 Me gusta
Responder
Soluciones aceptadas (1)
791 Vistas
7 Respuestas
Respuestas (7)
pendean
Community Legend
Community Legend
Post that DWG file and remind everyone what variant and year-version of AutoCAD you are using please.
0 Me gusta
cadffm
Are you sure your segments are long enough for a linetype pattern, or is the polyline set to generates linetypes(last property in palette)
Sebastian
0 Me gusta
No aplicable
Thank you for your quinck reply, here is the dwg file. I'm using Autocad 2018. version: O.49.0.0 on win 10, Intel core i7/4770S, 16GB ram.
0 Me gusta
No aplicable
I tried already both linetype generation on and off and I have changed only when I hoovered over it, in the preview. segments are long enough, even if i change linetype scale of the polyline it is not getting better.
0 Me gusta
cadffm
Solución aceptada
Your polyline and setting looks fine, Did you test that with exactly the provided file, just open the file and it looks like your picture?
command: 3Dconfig
Set HardwareAcceleration on or off changes nothing ?
command REGEN ?
2DRETAINMODE=0 ? (only for testing)
Sebastian
0 Me gusta
No aplicable
Helped turning off the hardware acceleration!
REGEN and 2DRETAINMODE=0 did nothing.
And yes, I had problem with exactly that file. Could you please explain me in a simple way (if it is possible) what is the difference between hardware acceleration on and off? I have to say, that I had already problem with construction lines when HA was on.  So I don't know if it is usefull to keep it on...
Thank you a lot for your help!
0 Me gusta
cadffm
"in a simple way (if it is possible) what is the difference between hardware acceleration on and off? "
https://en.wikipedia.org/wiki/Hardware_acceleration
Your graphic-driver is not the right or not uptpdate,
or/and
your Settings are not set properly
or/and
your graphic card/chipset (or there drivers)  only partially support the required functions for AutoCAD.
Sebastian
0 Me gusta
