Hello!
I am quite new to AutoCAD especially in terms of plotting and I have this problem (see attachments (they are captures from model space)).
So although the cyan line is a single polyline (with many vertexes) the dashed line type displays only partially not as a whole. Now is it normal and if so how to get it as a continuous dashed line? The line itself was exported from Rhino as a Spline. I converted it into Polyline because the corners did not display properly with the dashed line.
In general, I had a lot of line type scale problems with this file as for example when I was zooming in and out in plot space the line type was scaling. Since I couldn't solve that I imported the drawing as a block into a new file what helped but now I have the problem described above.
Additionally, could you let me know if it is a normal practice to use Ctrl+C and Ctrl+V to move linework from one file into the other? That's how I have been compiling different linework so far and it may have something to do with all the problems?
