Polyline addeting
Polyline addeting
No aplicable
So somting weired is happening to my AUTOCAD, he "forgets" some keys and options that I used to work with every single day...
Know I can't add vertex to a polyline by hiting the "CTRL" key whike hoovering on the grippes. I don't use the properties menu, just the dynamic input and short keys in commond line.
what happend, can any one help please?
0 Me gusta
Responder
Soluciones aceptadas (1)
441 Vistas
4 Respuestas
Respuestas (4)
Thomas_Stuehle
Hello @Anonymous
Welcome to the AutoCAD forum.
On my side the adding vertex function works well without using CTRL.
When I press CTRL on the selected line the context menu completely deactivates and after moving a vertex a copy of the polyline is created. I tested this behavior from 2021 down to 2017 and it seems to be as designed.
Would you explain more in case I misunderstood and tell me which version you used before?
Did the post helped you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
0 Me gusta
imadHabash
Solución aceptada
if your GRIPMULTIFUNCTIONAL system variable = 3 , you can stop over the grip and add a vertex from the appeared menu.
Imad Habash
No aplicable
H i never used the double click to add vertex, only the CTRL key.
WHEN you select the polyline/polygone hower with your mouse on the middle
of any line you can see that there is a "plus" symbole appearing. when I
click in this while holding CTRL key it could add/delete/make arc of that
selected section
now it doesnt work
0 Me gusta
No aplicable
Thank you so mutch!!! Yes it is fixed bless you
