Polyine Data Extraction XYZ Data
Message 1 of 25
I'm trying to extract object data from a drawing to excel. I have a lot of clsoed polyines and I want to export the Area as well as the Z coordiante. The "dataextraction" command will give me area, but it wont give me z coordinate, or any coordiantes for a polyine. Is there a better way to get the information I am looking for. It really should be built into the dataextraction command.
Thanks for any and all help.
Replies (24)
Message 2 of 25
wispoxy
Add a field with command ATTDEF then sync with ATTSYNC.
Message 3 of 25
wispoxy
You'll need probably need a LISP Routine for your coordinate specifics then create a field. In fact you can attach LISP to a field.
Message 4 of 25
Patchy
Dataextraction doesn't get coord of polylines only lines.
Message 5 of 25
Kent1Cooper
I'm on an older version here, so I can't check, but if they're Lightweight Polylines, their Z coordinate is stored not as part of their vertex locations, but rather in their elevation [the Elevation VLA Property, or the DXF code 38 entry in entity data).  Can DATAEXTRACTION get that, even though it can't get vertex Z coordinates?
Kent Cooper, AIA
Message 6 of 25
wispoxy
Autodesk never did make coordinate extraction easy. I do it all through an AutoCAD excel plugin.
Message 7 of 25
Kent1Cooper
@Kent1Cooper wrote:
I'm on an older version here, so I can't check, but if they're Lightweight Polylines, their Z coordinate is stored not as part of their vertex locations, but rather in their elevation ....  Can DATAEXTRACTION get that, even though it can't get vertex Z coordinates?
If Help for 2016, here for the Data Extraction Wizard, in the Select Properties area, is correct that "Properties are the same as those listed in the Properties palette," then although the image there doesn't go far enough down to see it, Elevation should be one that you can include -- it's certainly in the Properties palette in my older version here, so I imagine it must still be there in newer ones.
Kent Cooper, AIA
Message 8 of 25
leeminardi
Give the LIST command and then select the polyline.
Select the area and coordinates in the text window and copy and paste into Excel.
After pasting into Excel it will look like this.
Delete the columns you do not want.  If when you do the paste the values do not go into separate columns, you can use  Excel's Data, Text to Columns and specify space as the delimiter.
~Lee
lee.minardi
Message 9 of 25
leeminardi
If you are going to use VLISP to extract 3D coordinates of a LWPOLYLINE you can extract the unit vector normal of the plane containing the polyline (DXF code 210) and the distance that plane is from the WCS origin (DXF code 38).  Multipling the two together gives you the location in WCS coordinates of the origin of the plane containing the polyline.  The x direction for this plane can be found by taking the cross product of the WCS z axis (0,0,1) and the polyline plane normal.  The y axis is the normal cross the x axis (of the polyline).  Knowing the unit vectors in x and y of the plane you can calculate a point's 3D WCS cooridnates by vector addition.  Not difficult but tedious.    I think using the LIST command I mentioned is much easier unless you are going to do this alot!
~Lee
lee.minardi
Message 10 of 25
wispoxy
@leeminardi That looks the same or similar to what my plug-in does, well said.
Message 11 of 25
I'm going to have several hundred polylines, listing a copying and pasting will take to much time.
Message 12 of 25
Kent1Cooper
@lminardigmail wrote:
If you are going to use VLISP to extract 3D coordinates of a LWPOLYLINE ....
But I'm not, and the OP doesn't want to, if I'm interpreting the original question correctly.  They want the "Area as well as the Z coordinate."  Partly because of that being in the singular, and partly because it's hard to imagine a reason to want all the Z coordinates of vertices without the X & Y coordinates, I took that to mean they're just looking for the Polyline's elevation, the one Z coordinate that applies to all its vertices.  Unless they write back to say I misunderstood, I'll try when I'm at my newer-version location, but maybe someone out there can answer the question at the end of Post 5 sooner -- can DATAEXTRACTION include the Elevation Property?
[Further EDIT:  Now I'm noticing the Subject line that includes XYZ, so I'm wondering whether they do want all XYZ vertex locations, and if so, why only the Z coordinate is mentioned in Post 1.]
Kent Cooper, AIA
Message 13 of 25
Alfred.NESWADBA
That needs to make sure that all 2D-/LW-Polylines are parallel to WCS! If not the polylines vertices will have different Z-values for each XY position and will not be equal to the "Elevation" property.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 14 of 25
Kent you are correct, I only want the Z elevation and Area for the entire polyline.
No the elevation is not an option for export. Its really saddening how limited my options are.
I need to know what the volume is at every inch for a non uniform shape. I'm going to have polylines similar to this, cut every 1" for 50'. I will use the Z elevation to tell me the order, and the area to calc the volume for that 1" slice.
Data Extraction Looks like this.
Now there are a ton of options here and I have looked through them all. What Im looking for should be under misc. or Geometry.
Which only leaves me with this. If it exported in an order that made sense it would work but in my small sample set the order is random. which is why I need the Z Elevation Value.
-Chris
Message 15 of 25
All my Z values will be parallel to the WCS and thus the same across the entire 2d polyine section. Each section will be at a 1" set interval too. I only need the Z value to determine the order of the area values for the polyines.
Message 16 of 25
leeminardi
Chris,  If what you really want is the volume, and you have a series of closed polyline, why not just use LOFT to make a solid out of the sections and use MASSPROP to determine the volume?  It will be approximately as accurate as doing it by summing 1" thick slabs.
Also, using your method, if you know that the sections are 1" apart you do not need to know their elevation.  Just multiply the sum of the areas by 1" to get the volume.
~Lee
lee.minardi
Message 17 of 25
Kent1Cooper
Then I assume you'll need something like an AutoLisp routine to get the two Properties [Area and Elevation] from the Polylines and feed them out to a file.  It shouldn't be difficult.  What format should the extracted Properties be in, in relation to each other?  That is, what should a line in such a file look like?
Alternatively, a routine could get those Properties and sort them into Elevation order within itself, and only feed out to an external file the Areas, already in the correct order.  Does that sound viable?
Kent Cooper, AIA
Message 18 of 25
leeminardi
The areas do not need to be in the correct order to determine the volume.  They would if you were computing center of mass or moment of inertia.
~Lee
lee.minardi
Message 19 of 25
ВeekeeCZ
Perhaps simple lisp like this...
Spoiler
(vl-load-com)
(defun c:PLList ( / *error* i file en rep erea elev)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if file (close file))
    (princ))
  (if (and (setq file (open (getfiled "Define name of exported file" (getvar 'DWGPREFIX) "csv" 1) "a"))
	   (princ "\nNeed closed polylines,")
	   (setq ss (ssget '((0 . "LWPOLYLINE") (-4 . "&") (70 . 1))))
	   (write-line "Area,Elevation" file)
    (repeat (setq i (sslength ss))
      (if (and (setq en (ssname ss (setq i (1- i))))
	       (setq area (vlax-get (vlax-ename->vla-object en) 'area))
	       (setq elev (cdr (assoc 38 (entget en)))))
	(progn
	  (setq rep (strcat (rtos area) "," (rtos elev)))
	  (terpri) (princ rep)
	  (write-line rep file)))
  (*error* "end")
Message 20 of 25
Thanks for the lisp, this does exactly what I need.
Post 16 - Lee, I dont need the total volume, I need to be able to know the volume at every 1 inch increment. So that I can know that to fill the void another inch is going to take another X amount of material.
Post 17 - Kent, Yes a lisp will work, as has been created here.
Thanks for everyones help.
-Chris
