Polygonial Viewport Won't Lock
Message 1 of 12
Whenever I create a polygonial viewport, and rick click on the viewport to get the options to lock it, the option is not there. I have to create a rectangular viewport, lock it, and then use the viewport clip to edit the rectangle into a polygon. Then the viewport will be locked. I used to be able to create a polygonial viewport and lock it. I don't know what happened. I am using AUTOCAD 2015
Replies (11)
Message 2 of 12
jackshield
cant replicate
Message 3 of 12
Let me rephase my question:
When I create a polygonial viewport, I cannot lock it.
Message 4 of 12
rkmcswain
Can you lock the viewport any other way?
  + Select the viewport and click the lock/unlock icon in the status bar.
  + Select the viewport and change the "Display Locked" setting in Properties
Just as a test, make sure that _only_ the viewport is selected. When you select a non-rectangular viewport the polygon associated with it can be selected as well.
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 12
jackshield
good point.  thats why i like using the properties box
Message 6 of 12
I can lock it using the properties box.
I lost the ability to right click the viewport and lock/unlock from there.
Message 7 of 12
rkmcswain
Starting with something simple.
Is PICKFIRST set to 1?
Message 8 of 12
Sorry, tried that on a rectanglular viewport.
I am still not able to lock/unlock a polygonal viewport.
Message 9 of 12
No, I changed it and it still did not work.
Message 10 of 12
jackshield
post file?
Message 11 of 12
Alfred.NESWADBA
have you done any customizations to your menu or have you had migrated settings from an older release of AutoCAD?
Are you speaking about AutoCAD or do you have a vertical product like Map3D, Civil3D, Architecture, ...?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 12 of 12
 I figured it out (two weeks later)
The Selection Cycling must be turn off.
