Polygonal Viewport Transparency Issue
brendon_butler
brendon_butler
I've just discovered that Polygonal Viewports are not displaying transparency settings. Transparency can be set via layer manager and will appear fine within model and will also appear if using a rectangular viewport. But, not polygonal viewports.
Can anyone suggest if this is a bug or perhaps a setting change to fix this issue???
Cheers
Brendon
Alfred.NESWADBA
Can you upload a drawing that shows your issue.
The are many ways to use transparency, so it would be great to see what you mean (especially as I don't know what a viewport-transparency should result in, besides of the border of the viewport get's transparent).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- alfred -
I believe that he's talking about making layers transparent via the VP specific options in Layer Manager.
brendon_butler
jherbst is correct in explaining that I am speaking of VP Transparency via layer manager.
With a fresh set of eyes and delving deeper this morning. I have worked out that in fact my issue is not directly as a result of polyagonal VP not working exactly as I have successfully made a simple solid hatch turn transparent within a polygonal VP.
My issue seems to be with an ECW Aerial image. Again, VP transparency works fine for rectangular VP's but not Polygonal VP's.
Any ideas based on that refinement to the issue?
Cheers
Brendon
Victoria.Studley
Hi @brendon_butler,
Thank you for posting your question, and clarifying that the aerial image is not reacting to viewport transparency in polygonal viewports.
Do you have Hardware Acceleration disabled? If so, this may be a known issue.
You can either enable Hardware Acceleration or utilize the raster image "FADE" option instead of using viewport transparency.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
brendon_butler
Thank you Victoria!!
Enabling Hardware Acceleration was the answer.
Cheers everyone for your assistance!
Brendon
Victoria.Studley
I'm glad to hear that fixed it for you, @brendon_butlerSmiley Happy
Victoria Studley
