Anuncios
Polygon/Clipped Viewports Not Showing
ryan1949
ryan1949
When using polygon or clipped viewports in AutoCAD 2023, the model space and all objects in paper space disappear and do not show accurately. This only happens with these non rectangular viewports. See image attached.
0 Me gusta
Responder
Soluciones aceptadas (1)
653 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
Have you installed the 2023.1.2 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables: if still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, share that DWG file over here, we all have AutoCAD2023 and can test it for you.
TIA
0 Me gusta
ryan1949
Solución aceptada
The software was up to date. Setting the GFXDX12 to 0 solved the issue.
