polar array work flow
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Please somebody give me a work flow for using polar array that will work 1st time every time.
To this day I have never managed a polar array 1st time without retrying or editng a few times.
I have objects that want to array a certain angle and a certain number of  times.
The 2  do not seem to be mutual, I can never seem to enter them in at the same time without the array being
messed up.
Mike Kovacik
Autocad 2018
Autocad/Inventor 2d/3d designer/draughtsman
Joburg South Africa
imadHabash
try to use Array through a contextual ribbon interface. also make sure that your AutoCAD is full updated . >> Click <<
Imad Habash
MikeKovacik4928
okay
I finally found out how to do it, first time around.
further experimenting has showed you can't enter in number of items and angle between from the menu both at one time,
but have to enter the one, then use the little edit arrow to enter in the other.
Mike
vinodkl
You can enter both at once from the menu while using polar array.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
