I am trying to make a pattern in autocad of rectangular pavers in a radial pattern all based from one central point, the problem I have run into is that I have to make a new array for every ring, then having to increase the number of my objects in that polar array. I am attempting to do this on a very large scale, and was wondering if there was a faster way to create this type of pattern. Increasing the number of rows does not work because of the space created between the rectangles when you start to get farther from the center point. If there was a way to easily create multiple polar arrays then simply change the number of objects in everyone to keep the rectangles close to each other in each concentric circle, that would save me a lot of time
Thanks--
