Points on top of Points
bpeters33
Observer
bpeters33
Observer
Observer
Is there a tool that will prevent points from being imported on top of points?  My issue is I have data points that don't have to be imported into my dwg with great precision, but some have identical coordinates, which causes them to be brought in on top of each other, and thus, I can't tell visually how many there are.  ArcGIS has a tool called "Disperse" and I'm wondering if AutoCad has a similar tool.
0 Me gusta
Responder
Soluciones aceptadas (1)
538 Vistas
7 Respuestas
Respuestas (7)
Kent1Cooper
OVERKILL can remove duplicates.  EDIT:  If you don't want to do that, but only want to know how many Points there are, select a whole area of objects of any kinds, and pull down the object-type(s) list in the Properties palette:
Further EDIT:  Or use SELECTSIMILAR and pick any Point, and the Properties palette will show you how many.
Kent Cooper, AIA
0 Me gusta
bpeters33
Observer
Observer
I don't want to remove the duplicates, I want to offset them so that I can still see them.
0 Me gusta
Kent1Cooper
If you want to see them only to know how many there are, see my Edit to my previous reply.
A routine could be made to find duplicates and move some, though I wonder about the validity of moving data points -- what does that do to the data aspect?  But in any case, there would need to be some criteria.  How far to move them?  In what direction?  Might there ever by more than two in the same place, so that some would need to be moved different distances or in different directions than others?  Etc.
You could also try over in the Civil3D or maybe AutoCAD Map Forum, where people who may have the same kind of need are likely to hang out.
Kent Cooper, AIA
0 Me gusta
bpeters33
Observer
Observer
Thanks.  I appreciate it.
0 Me gusta
parkr4st
what is the import process?  all points in one import or several imports?
maybe layers for each import, qselect by layer and change the Z value for each layer?
view from a corner of the cube would show the points separated by elevation.
data extracton would then have the Z value making the points not coincident
leeminardi
Solución aceptada
Here's a way to do it with Excel and AutoCAD.
1. Import the point data into Excel and then sort. This should yield duplicate points consecutively.
2.  Layout the worksheet as seen below. Cells A1 and B1 contain the desired offset for duplicate points.  The data starts on row 3.
3. Cell C3 = 0. while cell C4 is:
=IF(AND(A4=A3,B4=B3),C3+1,0)
Fill column C all the way down from C4 to the last row of data.
4. Cell D3 is:
=CHOOSE($C3+1,A3,A3+A$1,A3+2*A$1)
and E3 (fill right from C3) is:
=CHOOSE($C3+1,B3,B3+B$1,B3+2*B$1)
Fill columns D and E down to the last row of data.
5. Cell G3 is:
=CONCATENATE("point ",D3,",",E3)
Fill down then copy and paste this column into AutoCAD.
The result should look something like this.
lee.minardi
bpeters33
Observer
Observer
That's actually what I ended up doing, except I only moved the Y coordinate so that they're aligned vertically.  Thanks.
0 Me gusta
